Tofu65 Keyboard PCB Replacement
  1. Tofu65 Keyboard PCB Replacement, Keyboard PCB: step 1, image 1 of 1
    • Unplug the power cord.
  2. Tofu65 Keyboard PCB Replacement: step 2, image 1 of 1
    • Use a keycap puller to remove the keycaps from the keyboard.
    • Be sure to pull straight up when removing the keycaps to avoid damaging the key switches.
  3. Tofu65 Keyboard PCB Replacement: step 3, image 1 of 1
    • Use the switch puller to pinch the switch on the two pins to release the switch from the PCB.
    • Pull straight up when removing the switch. It should not take much force to pull them out.
  4. Tofu65 Keyboard PCB Replacement: step 4, image 1 of 2 Tofu65 Keyboard PCB Replacement: step 4, image 2 of 2
    • Remove the plastic cover that protects the PCB.
  5. Tofu65 Keyboard PCB Replacement: step 5, image 1 of 2 Tofu65 Keyboard PCB Replacement: step 5, image 2 of 2
    • Gently remove the foam layer protecting the PCB.
  6. Tofu65 Keyboard PCB Replacement: step 6, image 1 of 3 Tofu65 Keyboard PCB Replacement: step 6, image 2 of 3 Tofu65 Keyboard PCB Replacement: step 6, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the six 5 mm screws keeping the PCB in place.
  7. Tofu65 Keyboard PCB Replacement: step 7, image 1 of 2 Tofu65 Keyboard PCB Replacement: step 7, image 2 of 2
    • Remove the old PCB from the bottom case.
  8. Tofu65 Keyboard PCB Replacement: step 8, image 1 of 2 Tofu65 Keyboard PCB Replacement: step 8, image 2 of 2
    • Ensure your keyboard switches are in good condition and the golden pins are not bent.
    • If the pins are bent, carefully bend them so they are straight or replace them with new switches.
  9. Tofu65 Keyboard PCB Replacement: step 9, image 1 of 3 Tofu65 Keyboard PCB Replacement: step 9, image 2 of 3 Tofu65 Keyboard PCB Replacement: step 9, image 3 of 3
    • Replace your PCB.
    • Place the foam and plastic plate cover back.
    • Line up the key switch pins with the sockets on the PCB before installing them.
    • Install the keyboard switches and apply a small amount of force to ensure they make contact with the PCB.
  10. Tofu65 Keyboard PCB Replacement: step 10, image 1 of 2 Tofu65 Keyboard PCB Replacement: step 10, image 2 of 2
    • Replace each keycaps onto the appropriate switch.
    • Press down firmly on each to ensure they are making contact.
Finish Line
Daniel Payan
202 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 57
All Time: 833
