Toilet Keeps Running: How to Fix & Maintain Valve Seat
  1. Toilet Keeps Running: How to Fix & Maintain Valve Seat, Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 1, image 1 of 1
    • Remove the lid from the toilet tank.
  2. Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 2, image 1 of 1
    • Flush the toilet, and hold down the flush lever until the tank is completely empty.
  3. Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 3, image 1 of 1
    • Gently lift the float up, ending the flow of water. This will prevent the toilet tank from refilling.
  4. Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 4, image 1 of 3 Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 4, image 2 of 3 Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 4, image 3 of 3
    • Pull up the valve seat. If possible, keep it raised without releasing the float.
    • If you do not have assistance, you may need to hold these in place with one hand. This will keep your other hand free for the next step.
    • Some toilets may use a float ball to control overflow.
  5. Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 5, image 1 of 2 Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 5, image 2 of 2
    • Wipe the valve seat with a rag or towel to remove the calcium deposits. Don't forget to wipe the bottom of the valve seat, as deposits can form there as well.
  6. Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 6, image 1 of 2 Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 6, image 2 of 2
    • Release the float and the valve seat, and allow them to fall back into place. The flow of water will resume.
  7. Toilet Keeps Running: How to Fix & Maintain Valve Seat: step 7, image 1 of 1
    • Place the lid back on the tank.
Finish Line
Roman Snow
169 Reputation
1 Guide authored
3 Comments
Cutting off the water supply, draining the tank and spraying the seat with vinegar or CLR does the same thing -dissolving the calcium carbonate. You can prevent calcium carbonate buildup by putting a piece of magnesium in the tank.
P Schmied - Reply
Thanks for Step #7. Always forget that one!
Matt Heckel - Reply
You may use a calcium remover for toilets. If you have patience and willingness, you can make a DIY toilet cleaner composed of vinegar, lemon, other acidic liquids, and baking soda. Thick calcium deposits in the toilet require muriatic acid and deep scrubbing with scour paper.
lim anna - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 938
