Toilet Seat Replacement
  1. Toilet Seat Replacement, Toilet Seat: step 1, image 1 of 1
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Toilet Seat Replacement: step 2, image 1 of 2 Toilet Seat Replacement: step 2, image 2 of 2
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. Toilet Seat Replacement: step 3, image 1 of 3 Toilet Seat Replacement: step 3, image 2 of 3 Toilet Seat Replacement: step 3, image 3 of 3
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  4. Toilet Seat Replacement: step 4, image 1 of 2 Toilet Seat Replacement: step 4, image 2 of 2
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  5. Toilet Seat Replacement: step 5, image 1 of 1
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  6. Toilet Seat Replacement: step 6, image 1 of 1
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
To re-install your previous seat, follow these instructions in reverse order.
2 other people completed this guide.
Christopher Carter
231 Reputation
1 Guide authored
Cal Poly, Team 24-5, Green Winter 2015 Member of Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,950
