Introduction
The blades on the Nose & Ear trimmer eventually wear out and require replacement. The following steps will guide you through how to safely and successfully replace these blades.
Twist the tip of the trimmer counterclockwise to remove it.
The trimmer blade assembly will be located on the inside of the tip.
Almost done!
