Tolino Shine Screen Replacement
  1. Tolino Shine Screen Replacement, Remove front cover: step 1, image 1 of 3 Tolino Shine Screen Replacement, Remove front cover: step 1, image 2 of 3 Tolino Shine Screen Replacement, Remove front cover: step 1, image 3 of 3
    • The front cover and back cover are glued together, we want to open the device by squeezing something in between, e.g. a not too sharp knife
    • Once you made an opening between the two covers, go around the whole device. I used a plastic little tool not to damage whatever is underneath, but you can use the knife as well.
    ...leider funkioniert dieser Anwendungstip nicht ohne Warmluft - Foen. Das dünne Gehäuse bricht sonst.
    Leider erhält man keine Möglichkeit zum Nachbestellen eines Gehäuses vom Hersteller.( z.B.: Gerät zu alt oder andere Ausreden!) Gemäß dem Motto wegschmeißen... und Neu kaufen... War ja bekantermaßen Gestern ;-)
    Reparieren ist Trumpf und gibt ein gutes Gefühl! Für die Umwelt....
    Gast - Reply
  2. Tolino Shine Screen Replacement, Remove the back cover: step 2, image 1 of 1
    • Remove the back cover by unscrewing the 4 screws indicated in red
  3. Tolino Shine Screen Replacement, Disconnect the battery and screen: step 3, image 1 of 2 Tolino Shine Screen Replacement, Disconnect the battery and screen: step 3, image 2 of 2
    • First disconnect the battery by pulling the red and black cable (indicated with a red circle) away from the printboard. You might have to pull quite hard
    • Disconnect the first screen cable by lifting the black piece of the long connector (indicated in yellow) away from the circuit board. The cable should then slide out
    • Disconnect the second cable (marked in blue) of the screen by lifting the white part of the connector. Once the white part is up, the cable slides out.
    • unscrew the screen from the print board (screws indicated in black on the first picture)
  4. Tolino Shine Screen Replacement, take off the screen: step 4, image 1 of 3 Tolino Shine Screen Replacement, take off the screen: step 4, image 2 of 3 Tolino Shine Screen Replacement, take off the screen: step 4, image 3 of 3
    • Squeeze something between the print board and the screen to take it off. The screen is glued at certain spots, so the screen will scatter in pieces.
    • After you separated the two you end up with a screen in a black frame. Make sure that there is no more glass sticking to the back of the print board.
    • Next, take the broken screen out of the black frame by pushing it out with your fingers.
  5. Tolino Shine Screen Replacement, Put the new screen in: step 5, image 1 of 3 Tolino Shine Screen Replacement, Put the new screen in: step 5, image 2 of 3 Tolino Shine Screen Replacement, Put the new screen in: step 5, image 3 of 3
    • Take of the protective plastic from the cover
    • Put the black frame on the screen
    • Pull the cables through the print board
    • Click the print board on the two pins of the black frame. One of them is indicated on the picture with a pink arrow
  6. Tolino Shine Screen Replacement, connect the new screen: step 6, image 1 of 3 Tolino Shine Screen Replacement, connect the new screen: step 6, image 2 of 3 Tolino Shine Screen Replacement, connect the new screen: step 6, image 3 of 3
    • First connect the small connector, then the bigger one. Push the cables all the way in the connectors and close them. Make sure you push the cables in far enough. Close the small connector by pushing the white part of the connector down towards the cable and close the big connector by pushing the black part down away from the cable
    • Once the screen is reconnected you can reconnect the battery by pushing the connector back in from the top down (see third picture).
    • Fix the screen on the board by screwing the screws back in place
  7. Tolino Shine Screen Replacement, test + reassembly: step 7, image 1 of 2 Tolino Shine Screen Replacement, test + reassembly: step 7, image 2 of 2
    • put the tolino back in it's back cover. Mind that the on switch fits well on the switch of the plastic cover (see blue circle on picture)
    • Flip the on switch once to see if the screen works. Also test the touch and the backlight. If one of them does not work, take the back cover off again and reconnect the cables of the screen.
    • If everything works screw the screen in place (see red circles)
    • click the front cover on again and you're done!
5 other people completed this guide.
Francis Santens
995 Reputation
2 Guides authored
10 Comments
I've dove all the steps, but the touch screen is unresponsive (the Device turn on) any help please
Oenis Zair - Reply
I have the exact same issue. Did you find any solutions?
Philipp de Sombre -
Hi,
Have you tried disconnecting and reconnecting the cables?
Francis Santens - Reply
Same here, and I also tried reconnecting all the cables! Somebody who found a solution?
Laura Baets -
Hello Francis,
Where can i find a screen for tolino shine 2? I’ve cracked mine and i cannot find any screens. Could you give me some links? And can you tell me if i can put other screens, like from kobo or kindle, that can work on tolino shine 2? Is it possible to replace the screen with other than Tolino’s?
Thank you
Busuric George - Reply
Hi,
You can find the serial number of your screen back on the cable connecting the screen to the device, so if you open up the Tolino until step 3 you’ll find a serial number at the back of the largest cable. In case of the Shine 1 it’s ED060XG1 LF , maybe it’s something else with you. You google that serial number and you’ll find a lot of shops selling them. It could be that it’s branded for another type of e reader like kobo, but that does not matter, multiple manufacturers use the same components, you just have to make sure that the serial code is the same because screens with different serial numbers are not cross compatible.
Good luck
Francis Santens -
Where can i by such a display for a tolino shine 3
Silvio Stoof - Reply
If your Tolino does not respond, try resetting it.
Link to German instructions (use Google translate or something else):
https://mytolino.com/faq/my-tolino-eread...
For this device here (quote from above source):
(tolino vision, tolino vision2, tolino vision 3, tolino vision 4, tolino shine, tolino shine 2, tolino page)
To perform a reset, simply press the reset button. This is located in a small opening on the bottom of your tolino eReader. Insert a bent paper clip, for example, into the opening until you feel a slight resistance. Your tolino eReader will then restart.
Tosnic - Reply
Thanks for the guide - Was able to fix my Tolino Shine 2 HD with it!
In case someone else with a Shine2HD is trying to follow the guide
There were some differences (or I did a mistake at step#4):
* Different screen (found correct one with this comment (see above))
* Instead of the front-cover, step#1 removes the back-cover
* Thus I did step#3 next
* Then removal of front cover: I cautiously pried it away with my hands, paying attention to the difference between the metal-sheet the printboard is on and the black front-cover
* Then step#4 (Take off the screen): The screen is glued onto the metal-sheet (which sits between screen and printboard) - I've had to carefully pry away all the glass from the metal-sheet (especially where it was glued on). My recommendation: Do this in a tray, since this step involves lots of splinter of glass, use gloves (for safety) and use a jimmy/knife (Also: This takes quite some time)
* Placed the screen where the old one was (based on glue), didn't put new glue on, followed rest of guide
Gerhard Stingl - Reply
Hola gracias por la información, quisiera preguntar si nos puedes ayudar con un dato de donde comprar la pantalla , gracias 🙏😀
Pamela De La Fuente - Reply
Past 24 Hours: 27
Past 7 Days: 128
Past 30 Days: 403
All Time: 16,561
