Toloco EM26 Motor Replacement
  1. Toloco EM26 Motor Replacement, Motor: step 1, image 1 of 2 Toloco EM26 Motor Replacement, Motor: step 1, image 2 of 2
    • Using the black spudger, remove the two rubber covers to reveal the screws underneath.
  2. Toloco EM26 Motor Replacement: step 2, image 1 of 1
    • Unscrew the revealed screws on the bottom of the massage gun.
  3. Toloco EM26 Motor Replacement: step 3, image 1 of 2 Toloco EM26 Motor Replacement: step 3, image 2 of 2
    • Unscrew the small black screw on the edge of circular plate.
  4. Toloco EM26 Motor Replacement: step 4, image 1 of 1
    • Take off the cap of the massage gun, watch out the back part of the gun with the integrated circuit might fall off so make sure you secure it while taking off the cap.
  5. Toloco EM26 Motor Replacement: step 5, image 1 of 2 Toloco EM26 Motor Replacement: step 5, image 2 of 2
    • Remove the two 8.24 mm silver screws on the top of the lever arm with the Phillips #00 screwdriver.
  6. Toloco EM26 Motor Replacement: step 6, image 1 of 2 Toloco EM26 Motor Replacement: step 6, image 2 of 2
    • Remove the 14.85 mm black screw from the underside of the rotary arm with allen wrench attachment.
  7. Toloco EM26 Motor Replacement: step 7, image 1 of 2 Toloco EM26 Motor Replacement: step 7, image 2 of 2
    • Grasp the rotary arm and carefully pull up to remove it from the device.
  8. Toloco EM26 Motor Replacement: step 8, image 1 of 2 Toloco EM26 Motor Replacement: step 8, image 2 of 2
    • Remove the four 11.26 mm silver screws from each side of the motor frame with a Phillips #00 screwdriver.
  9. Toloco EM26 Motor Replacement: step 9, image 1 of 3 Toloco EM26 Motor Replacement: step 9, image 2 of 3 Toloco EM26 Motor Replacement: step 9, image 3 of 3
    • Remove the two 6.14 mm silver screws located on the top plate with a Phillips #00 screwdriver.
    • Grasp the plate and carefully pull up to remove the plate from the device.
  10. Toloco EM26 Motor Replacement: step 10, image 1 of 2 Toloco EM26 Motor Replacement: step 10, image 2 of 2
    • Remove the top of the motor and carefully pull it out of the device.
    • Be sure that the wiring is disconnected from the large motherboard.
Andy
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 81
All Time: 304
