TomTom GO Live 1535M Motherboard Replacement
  1. TomTom GO Live 1535M Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • It may be easier to start at the corners.
  2. TomTom GO Live 1535M Motherboard Replacement: step 2, image 1 of 2 TomTom GO Live 1535M Motherboard Replacement: step 2, image 2 of 2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Remove the screen and set it aside.
  3. TomTom GO Live 1535M Motherboard Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the logic board cables.
    • We highly advice that a pair of tweezers are used for this step to ensure no part is damaged.
  4. TomTom GO Live 1535M Motherboard Replacement: step 4, image 1 of 1
    • Remove the 3.6mm screws with a Phillips Screwdriver.
    • After removing the screws simply lift the logic board from the base.
Mathias Sagide
618 Reputation
5 Guides authored
USF Tampa, Team 19-4, Blackwell Spring 2014 Member of USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Member
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 697
