Tommy Hilfiger Quartz Watch Band Link Replacement
  1. Tommy Hilfiger Quartz Watch Band Link Replacement, Band Link: step 1, image 1 of 1
    • Place the watch on your wrist and approximate the number of links to be removed.
  2. Tommy Hilfiger Quartz Watch Band Link Replacement: step 2, image 1 of 1
    • Identify the arrows located directly on the links and point them downwards in the south position.
  3. Tommy Hilfiger Quartz Watch Band Link Replacement: step 3, image 1 of 3 Tommy Hilfiger Quartz Watch Band Link Replacement: step 3, image 2 of 3 Tommy Hilfiger Quartz Watch Band Link Replacement: step 3, image 3 of 3
    • Lay and secure the wristband on the watchband holder.
  4. Tommy Hilfiger Quartz Watch Band Link Replacement: step 4, image 1 of 3 Tommy Hilfiger Quartz Watch Band Link Replacement: step 4, image 2 of 3 Tommy Hilfiger Quartz Watch Band Link Replacement: step 4, image 3 of 3
    • Align the tip of the pin pusher on the pin.
    • Begin tapping the hammer with force to push the link pin out.
  5. Tommy Hilfiger Quartz Watch Band Link Replacement: step 5, image 1 of 2 Tommy Hilfiger Quartz Watch Band Link Replacement: step 5, image 2 of 2
    • Set aside the link pins and links that have been removed from the watch.
  6. Tommy Hilfiger Quartz Watch Band Link Replacement: step 6, image 1 of 3 Tommy Hilfiger Quartz Watch Band Link Replacement: step 6, image 2 of 3 Tommy Hilfiger Quartz Watch Band Link Replacement: step 6, image 3 of 3
    • In order to add links to the wristband, ensure that the arrows are pointing upwards in the north position.
    • Secure the wristband on the watchband holder.
  7. Tommy Hilfiger Quartz Watch Band Link Replacement: step 7, image 1 of 2 Tommy Hilfiger Quartz Watch Band Link Replacement: step 7, image 2 of 2
    • Align the link pins to be added on the holes that connect the desired link to the wristband.
  8. Tommy Hilfiger Quartz Watch Band Link Replacement: step 8, image 1 of 3 Tommy Hilfiger Quartz Watch Band Link Replacement: step 8, image 2 of 3 Tommy Hilfiger Quartz Watch Band Link Replacement: step 8, image 3 of 3
    • Use the hammer to gently tap the link pins into the holes until the pin is completely resting in position.
  9. Tommy Hilfiger Quartz Watch Band Link Replacement: step 9, image 1 of 1
    • Finally, place the watch on your wrist to determine if the links are secure and the fitment is comfortable.
    • If adjustments need to be made, refer to step 2 for the subtraction of links and step 6 for the addition of links.
Finish Line
Ayush Theyyil
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 75
All Time: 6,107
