Top button Compartment
  1. Top button Compartment, Top button Compartment: step 1, image 1 of 3 Top button Compartment, Top button Compartment: step 1, image 2 of 3 Top button Compartment, Top button Compartment: step 1, image 3 of 3
    • Insert the flat end of wide metal spudger into the seam of the plastic buffer surrounding the buttons and pry it open.
  2. Top button Compartment: step 2, image 1 of 3 Top button Compartment: step 2, image 2 of 3 Top button Compartment: step 2, image 3 of 3
    • Use A #00 Phillips head screwdriver and turn counterclockwise to remove the four indicated screws.
    • Set the screws aside.
  3. Top button Compartment: step 3, image 1 of 2 Top button Compartment: step 3, image 2 of 2
    • Apply pressure and turn counterclockwise to remove the indicated 2.5 mm screw.
Joseph DoctorPinkney
216 Reputation
2 Guides authored
Marist, Team 1-3, Laflen Spring 2016 Member of Marist, Team 1-3, Laflen Spring 2016
MARS-LAFLEN-S16S1G3
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 351
