TopMate C11 Fan Replacement
  1. TopMate C11 Fan Replacement, Fan: step 1, image 1 of 1
    • Place the cooler on a flat surface.
  2. TopMate C11 Fan Replacement: step 2, image 1 of 1
    • Flip the cooler upside down.
  3. TopMate C11 Fan Replacement: step 3, image 1 of 1
    • Identify all 10 metal flaps.
  4. TopMate C11 Fan Replacement: step 4, image 1 of 3 TopMate C11 Fan Replacement: step 4, image 2 of 3 TopMate C11 Fan Replacement: step 4, image 3 of 3
    • Straighten all 10 metal flaps with tweezers.
  5. TopMate C11 Fan Replacement: step 5, image 1 of 2 TopMate C11 Fan Replacement: step 5, image 2 of 2
    • Flip the cooler while securely holding the mesh grille cover.
  6. TopMate C11 Fan Replacement: step 6, image 1 of 3 TopMate C11 Fan Replacement: step 6, image 2 of 3 TopMate C11 Fan Replacement: step 6, image 3 of 3
    • Remove the mesh grille cover.
    • WARNING: Be careful with the mesh grille cover, it has sharp edges.
  7. TopMate C11 Fan Replacement: step 7, image 1 of 1
    • Identify the broken fan.
  8. TopMate C11 Fan Replacement: step 8, image 1 of 3 TopMate C11 Fan Replacement: step 8, image 2 of 3 TopMate C11 Fan Replacement: step 8, image 3 of 3
    • Trace the wire from the broken fan to the controller board.
  9. TopMate C11 Fan Replacement: step 9, image 1 of 3 TopMate C11 Fan Replacement: step 9, image 2 of 3 TopMate C11 Fan Replacement: step 9, image 3 of 3
    • Gently press two points on the top of the white plug with tweezers to disconnect the wire.
    • Don't use excessive force. The wire is fragile.
  10. TopMate C11 Fan Replacement: step 10, image 1 of 3 TopMate C11 Fan Replacement: step 10, image 2 of 3 TopMate C11 Fan Replacement: step 10, image 3 of 3
    • Replace the fan and connect the wire.
    • Make sure to put the fan in the correct orientation.
    • Make sure also the white connector is fully connected.
Dominic Botlero
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 671
