Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement
  1. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Safety precautions: step 1, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 2, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 2, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 2, image 3 of 3
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 3, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 3, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 3, image 3 of 3
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 4, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 4, image 2 of 2
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 5, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 5, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the tub: step 6, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the tub: step 6, image 2 of 2
    • Pull up on the brake lever to disengage the brake.
  7. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 7, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 7, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 7, image 3 of 3
    • Rotate the tub until the yoke and dish assembly sit directly below the tub.
  8. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 8, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 8, image 2 of 2
    • Push down on the brake lever to re-engage the brake.
    • Make sure that the brake is fully engaged.
  9. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 9, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 9, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 9, image 3 of 3
    • Use a 3/4 inch socket to remove the six nuts securing the tub to the dish.
  10. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 10, image 1 of 1
    • Remove the six drum clamp plates from the tub mounting points.
  11. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 11, image 1 of 1
    • Lift the tub up slightly by the gear ring to loosen the tub from the dish.
  12. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 12, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 12, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 12, image 3 of 3
    • The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the tub straight up from the dish and remove it from the device.
  13. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the engine plate: step 13, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the engine plate: step 13, image 2 of 2
    • Remove the four fasteners securing the engine plate:
    • Two 14 mm bolts
    • Two 3/4 inch nuts
  14. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 14, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 14, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 14, image 3 of 3
    • Slide the engine plate up and out of the device to remove it.
  15. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the V-belts: step 15, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the V-belts: step 15, image 2 of 2
    • Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
    • You don't need to fully remove these bolts—loosen them enough to create slack in order to remove and replace the belts.
  16. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 16, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 16, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 16, image 3 of 3
    • If you are replacing the belts, you can choose to cut the old ones to remove them.
    • Slide the belts off from the pulleys and remove them.
    • If you have trouble sliding the belts off, further loosen the four engine bolts to create more slack.
  17. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the pulley: step 17, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the pulley: step 17, image 2 of 2
    • Use a crescent wrench to loosen the two set screws on the pulley.
    • Reassembly tip: The pulley is keyed to install in only one position.
  18. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 18, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 18, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 18, image 3 of 3
    • Slide the pulley off the axle and remove it.
  19. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 19, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 19, image 2 of 2
    • Remove the key from the axle.
  20. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the driveshaft: step 20, image 1 of 1
    • Use a 4 mm hex key to loosen the set screw securing the lock collar.
    • There should only be one set screw. If the collar isn't loose, check the second hole for set screws.
  21. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 21, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 21, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 21, image 3 of 3
    • Use a screwdriver to pry and loosen the lock collar from the shaft.
    • Slide the lock collar off the shaft and remove it.
  22. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 22, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 22, image 2 of 2
    • Pull the driveshaft from the gear end and remove it.
  23. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the driveshaft bearings: step 23, image 1 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the driveshaft bearings: step 23, image 2 of 3 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Remove the driveshaft bearings: step 23, image 3 of 3
    • Pull and remove the pulley-side bearing from its recess.
    • During reinstallation, lubricate the bearing with some machine oil and tap it into place with a mallet.
  24. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 24, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement: step 24, image 2 of 2
    • Pull and remove the gear-side bearing from its recess.
  25. Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Reassembly tip: step 25, image 1 of 2 Toro Cement Mixer 68009HD 2018 Driveshaft Bearings Replacement, Reassembly tip: step 25, image 2 of 2
    • To install the gear-side bearing:
    • Lubricate the bearing with some machine oil and set it in place.
    • Slide the driveshaft into the bearing and tap the gear with a mallet to press the bearing into place.
Arthur Shi
282,244 Reputation
585 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,450 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 479
