You're viewing a previously published version of this guide.  View latest version
Older Newer
Toro Cement Mixer 68009HD 2018 Pulley Replacement
Arthur Shi
Arthur Shi
Last updated on December 9, 2020
20 - 30 minutes
Moderate
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1
This guide shows how to remove and replace the pulley or sheave for the Toro Cement Mixer 68009HD.
  1. Toro Cement Mixer 68009HD 2018 Pulley Replacement, Safety precautions: step 1, image 1 of 2 Toro Cement Mixer 68009HD 2018 Pulley Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 2, image 1 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 2, image 2 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 2, image 3 of 3
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 3, image 1 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 3, image 2 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 3, image 3 of 3
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 4, image 1 of 2 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 4, image 2 of 2
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 5, image 1 of 2 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 5, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the engine plate: step 6, image 1 of 2 Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the engine plate: step 6, image 2 of 2
    • Remove the four fasteners securing the engine plate:
    • Two 14 mm bolts
    • Two 3/4 inch nuts
  7. Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 7, image 1 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 7, image 2 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 7, image 3 of 3
    • Slide the engine plate up and out of the device to remove it.
  8. Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the V-belts: step 8, image 1 of 2 Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the V-belts: step 8, image 2 of 2
    • Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
    • You don't need to fully remove these bolts—loosen them enough to create slack in order to remove and replace the belts.
  9. Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 9, image 1 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 9, image 2 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 9, image 3 of 3
    • If you are replacing the belts, you can choose to cut the old ones to remove them.
    • Slide the belts off from the pulleys and remove them.
    • If you have trouble sliding the belts off, further loosen the four engine bolts to create more slack.
  10. Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the pulley: step 10, image 1 of 2 Toro Cement Mixer 68009HD 2018 Pulley Replacement, Remove the pulley: step 10, image 2 of 2
    • Use a crescent wrench to loosen the two set screws on the pulley.
    • Reassembly tip: The pulley is keyed to install in only one position.
  11. Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 11, image 1 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 11, image 2 of 3 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 11, image 3 of 3
    • Slide the pulley off the axle and remove it.
  12. Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 12, image 1 of 2 Toro Cement Mixer 68009HD 2018 Pulley Replacement: step 12, image 2 of 2
    • Remove the key from the axle.
Arthur Shi
283,033 Reputation
587 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,533 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 14
