Toro Cement Mixer 68009HD 2018 V-Belt Replacement
Arthur Shi
Arthur Shi
Last updated on December 9, 2020
10 - 30 minutes
Moderate
Introduction
Go to step 1
This guide shows how to remove and replace the two drivetrain V-belts for the Toro Cement Mixer 68009HD.
  1. Toro Cement Mixer 68009HD 2018 V-Belt Replacement, Safety precautions: step 1, image 1 of 2 Toro Cement Mixer 68009HD 2018 V-Belt Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 2, image 1 of 3 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 2, image 2 of 3 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 2, image 3 of 3
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 3, image 1 of 3 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 3, image 2 of 3 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 3, image 3 of 3
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 4, image 1 of 2 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 4, image 2 of 2
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 5, image 1 of 2 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 5, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 V-Belt Replacement, Remove the engine plate: step 6, image 1 of 2 Toro Cement Mixer 68009HD 2018 V-Belt Replacement, Remove the engine plate: step 6, image 2 of 2
    • Remove the four fasteners securing the engine plate:
    • Two 14 mm bolts
    • Two 3/4 inch nuts
  7. Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 7, image 1 of 3 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 7, image 2 of 3 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 7, image 3 of 3
    • Slide the engine plate up and out of the device to remove it.
  8. Toro Cement Mixer 68009HD 2018 V-Belt Replacement, Remove the V-belts: step 8, image 1 of 2 Toro Cement Mixer 68009HD 2018 V-Belt Replacement, Remove the V-belts: step 8, image 2 of 2
    • Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
    • You don't need to fully remove these bolts—loosen them enough to create slack in order to remove and replace the belts.
  9. Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 9, image 1 of 3 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 9, image 2 of 3 Toro Cement Mixer 68009HD 2018 V-Belt Replacement: step 9, image 3 of 3
    • If you are replacing the belts, you can choose to cut the old ones to remove them.
    • Slide the belts off from the pulleys and remove them.
    • If you have trouble sliding the belts off, further loosen the four engine bolts to create more slack.
Arthur Shi
283,132 Reputation
587 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,547 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 571
