Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement
  1. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Disconnect the spark plug wire: step 1, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Disconnect the spark plug wire: step 1, image 2 of 2
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Flip the engine switch to the off position: step 2, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Flip the engine switch to the off position: step 2, image 2 of 2
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Close the fuel valve: step 3, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Close the fuel valve: step 3, image 2 of 2
    • Flip the fuel valve lever to the OFF position.
  4. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the control valve bracket bolts: step 4, image 1 of 1
    • Use a 3/8 inch socket to remove the three bolts securing the control valve to the control valve bracket.
  5. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 5, image 1 of 1
    • Use a 9/16 inch socket to remove the two bolts securing the control valve bracket to the frame.
  6. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the control valve bracket: step 6, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the control valve bracket: step 6, image 2 of 2
    • Remove the control valve bracket.
  7. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Prepare for fluid drips: step 7, image 1 of 1
    • Residual hydraulic fluid will be trapped in the hoses connected to the control valve, and may drip during the following procedure.
    • Place a bucket underneath the device, below the control valve to catch any hydraulic fluid drips.
    • Have rags handy to stop drips and clean up affected areas.
  8. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose: step 8, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose: step 8, image 2 of 2
    • Use an adjustable wrench to loosen the nut securing the output hose to the L-fitting on top of the control valve.
  9. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 9, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 9, image 2 of 2
    • Remove the output hose from the top L-fitting.
  10. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose: step 10, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose: step 10, image 2 of 2
    • Use an adjustable wrench to loosen the nut holding the input hose to the L-fitting on the bottom of the control valve.
  11. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 11, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 11, image 2 of 2
    • Remove the input hose from the bottom L-fitting.
  12. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the top L-fitting: step 12, image 1 of 1
    • Use an adjustable wrench to loosen the nut securing the top L-fitting to the control valve.
  13. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 13, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 13, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 13, image 3 of 3
    • Spin the top L-fitting counter-clockwise to remove it.
    • This fitting is part number 340-16.
  14. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the bottom L-fitting: step 14, image 1 of 1
    • Use an adjustable wrench to loosen the nut securing the bottom L-fitting to the control valve.
  15. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 15, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 15, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 15, image 3 of 3
    • Remove the bottom L-fitting.
  16. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the piston extension hose: step 16, image 1 of 1
    • Use an adjustable wrench to loosen the nut securing the piston extension hose to the L-fitting on the rear of the control valve.
  17. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 17, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 17, image 2 of 2
    • Remove the piston extension hose from the rear L-fitting.
  18. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the control valve: step 18, image 1 of 1
    • Use an adjustable wrench to loosen the nut securing the control valve to the cylinder.
    • This connection is the last part holding the control valve to the device, so keep the control valve supported during removal.
  19. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 19, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 19, image 2 of 2
    • Remove the control valve.
  20. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove leftover fittings: step 20, image 1 of 1
    • Use an adjustable wrench to loosen the nut securing the piston contraction fitting to the control valve.
  21. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 21, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 21, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 21, image 3 of 3
    • Spin the piston contraction fitting counter-clockwise to remove it.
    • This fitting is part number 100-7671.
  22. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 22, image 1 of 1
    • Use an adjustable wrench to loosen the nut securing the L-fitting to the rear of the control valve.
  23. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 23, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 23, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 23, image 3 of 3
    • Spin the L-fitting counter-clockwise to remove it.
    • This fitting is part number 340-98.
  24. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 24, image 1 of 1
    • Only the control valve remains.
  25. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose fitting O-ring: step 25, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose fitting O-ring: step 25, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose fitting O-ring: step 25, image 3 of 3
    • Use a pick tool to remove the O-ring from the output hose L-fitting, on the side that connects to the control valve.
    • This O-ring is part number 237-80.
    • The O-ring between the L-fitting and the hose is part number 237-58. Only replace this O-ring if it is visibly damaged.
  26. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose fitting O-ring: step 26, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose fitting O-ring: step 26, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose fitting O-ring: step 26, image 3 of 3
    • Use a pick tool to remove the O-ring from the input hose L-fitting, on the side that connects to the control valve.
  27. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder contraction fitting O-ring: step 27, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder contraction fitting O-ring: step 27, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder contraction fitting O-ring: step 27, image 3 of 3
    • Use a pick tool to remove the O-ring from the cylinder contraction fitting, on the side that connects to the control valve.
    • This O-ring is part number 237-79.
    • The O-ring between the L-fitting and the hose is part number 237-30. Only replace this O-ring if it is visibly damaged.
  28. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder extension fitting O-ring: step 28, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder extension fitting O-ring: step 28, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder extension fitting O-ring: step 28, image 3 of 3
    • Use a pick tool to remove the O-ring from the cylinder extension hose L-fitting, on the side that connects to the control valve.
Carsten Frauenheim
136,200 Reputation
371 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,533 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 294
