Torque King Electric RTR RC Monster Truck Antenna Replacement
  1. Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: step 1, image 1 of 2 Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: step 1, image 2 of 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Antenna Replacement: step 2, image 1 of 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Antenna Replacement, Loosen Screw: step 3, image 1 of 1
    • Loosen the 10mm screw surrounded by the copper using a #2 Phillips head screwdriver.
    • The wire that connects the antenna to the circuitry of the truck might be blocking the screw. Take care when moving the wire out of the way not to pull it from its soldering.
  4. Torque King Electric RTR RC Monster Truck Antenna Replacement, Remove Antenna: step 4, image 1 of 1
    • Carefully slide the antenna out from under the screw and remove.
Colton Sholtis
257 Reputation
2 Guides authored
Cal Poly, Team 6-30, Amido Winter 2015 Member of Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 521
