Toshiba Chromebook CB35-A3120 Speakers Replacement
  1. Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: step 1, image 1 of 2 Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: step 1, image 2 of 2
    • Using a Y1 screw driver head remove all ten .9mm screws from the back cover
    • Set the screws aside in preparation for reassembly
  2. Toshiba Chromebook CB35-A3120 Speakers Replacement: step 2, image 1 of 2 Toshiba Chromebook CB35-A3120 Speakers Replacement: step 2, image 2 of 2
    • Remove the back cover by placing a prying tool in the SD slot and popping the clips out of place.
  3. Toshiba Chromebook CB35-A3120 Speakers Replacement: step 3, image 1 of 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: step 3, image 2 of 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: step 3, image 3 of 3
    • Unscrew the battery by using a J1 screw driver head, and place the four .7mm screws off to the side
    • Using a pry tool, pop the battery connector out of place and gently lift the battery upward.
  4. Toshiba Chromebook CB35-A3120 Speakers Replacement: step 4, image 1 of 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: step 4, image 2 of 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: step 4, image 3 of 3
    • Remove the right side speaker by popping it out of place with your finger
    • Follow the speaker wire along the clips underneath the battery until you reach the left hand speaker
  5. Toshiba Chromebook CB35-A3120 Speakers Replacement: step 5, image 1 of 2 Toshiba Chromebook CB35-A3120 Speakers Replacement: step 5, image 2 of 2
    • Unplug the connector wiring the speaker to the mother board.
    • Pop the speaker out of the computer, similar to the method used in the previous step.
2 other people completed this guide.
Jayce Houghton
176 Reputation
1 Guide authored
USF Tampa, Team 15-6, Remmell Spring 2017 Member of USF Tampa, Team 15-6, Remmell Spring 2017
USFT-REMMELL-S17S15G6
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 751
