Toshiba Dynabook T552-58G Battery Replacement
  1. Toshiba Dynabook T552-58G Battery Replacement, Battery: step 1, image 1 of 1
    • Flip the computer so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Battery Replacement: step 2, image 1 of 2 Toshiba Dynabook T552-58G Battery Replacement: step 2, image 2 of 2
    • Push the right battery cover lock (labeled as number 1) to the right.
    • It should now be on the unlock symbol.
  3. Toshiba Dynabook T552-58G Battery Replacement: step 3, image 1 of 1
    • Push and hold the left battery cover lock (labeled as number 2) to the left.
    • It should now be on the number 2.
  4. Toshiba Dynabook T552-58G Battery Replacement: step 4, image 1 of 2 Toshiba Dynabook T552-58G Battery Replacement: step 4, image 2 of 2
    • While holding the left battery cover lock, pull up on the indent found in the center of the battery pack.
    • Lift up on the battery pack to remove it from computer.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 749
