Toshiba Dynabook T552-58G Space Bar Replacement
  1. Toshiba Dynabook T552-58G Space Bar Replacement, Space Bar: step 1, image 1 of 1
    • The space bar is located on the bottom of the keyboard.
  2. Toshiba Dynabook T552-58G Space Bar Replacement: step 2, image 1 of 2 Toshiba Dynabook T552-58G Space Bar Replacement: step 2, image 2 of 2
    • Gently pry the broken space bar up with from the back with your finger.
  3. Toshiba Dynabook T552-58G Space Bar Replacement: step 3, image 1 of 1
    • You should now see the key retainer.
    • Do not remove anything else because this is crucial for replacing the key.
  4. Toshiba Dynabook T552-58G Space Bar Replacement: step 4, image 1 of 3 Toshiba Dynabook T552-58G Space Bar Replacement: step 4, image 2 of 3 Toshiba Dynabook T552-58G Space Bar Replacement: step 4, image 3 of 3
    • Gently lift up the bottom metal prongs.
    • Insert the two ends of the prong into the small metal loops located at the top of the key pad.
    • Gently press the key down until you hear a click.
Finish Line
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 509
