Toshiba Encore Mini Battery Replacement
  1. Toshiba Encore Mini Battery Replacement, Battery: step 1, image 1 of 2 Toshiba Encore Mini Battery Replacement, Battery: step 1, image 2 of 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Battery Replacement: step 2, image 1 of 1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Battery Replacement: step 3, image 1 of 1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Battery Replacement: step 4, image 1 of 2 Toshiba Encore Mini Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Battery Replacement: step 5, image 1 of 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
5 other people completed this guide.
Erica Jouglard
263 Reputation
1 Guide authored
UW Tacoma, Team 1-3, Liner SU 2015 Member of UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Members
6 Guides authored
2 Guide Comments
Be sure to remove any SD cards you have first.
ecw0647 - Reply Share
But where do i buy the battery?
sissyhana - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 4,313
