Toshiba Encore WT8-A Tablet Camera Replacement
  1. Toshiba Encore WT8-A Tablet  Camera Replacement, Motherboard: step 1, image 1 of 1
    • Remove the 4 – 4.5 mm screws from the motherboard assembly.
  2. Toshiba Encore WT8-A Tablet  Camera Replacement: step 2, image 1 of 1
    • Remove the 2 – 3.5 mm screws from the motherboard assembly.
  3. Toshiba Encore WT8-A Tablet  Camera Replacement: step 3, image 1 of 1
    • The motherboard should come free at this point.
  4. Toshiba Encore WT8-A Tablet  Camera Replacement, Camera: step 4, image 1 of 1
    • Use small plastic opening tool for the following steps.
  5. Toshiba Encore WT8-A Tablet  Camera Replacement: step 5, image 1 of 2 Toshiba Encore WT8-A Tablet  Camera Replacement: step 5, image 2 of 2
    • Use small plastic opening tool to pry rear facing camera flat top connector from motherboard.
  6. Toshiba Encore WT8-A Tablet  Camera Replacement: step 6, image 1 of 1
    • The rear facing camera should come free at this point.
  7. Toshiba Encore WT8-A Tablet  Camera Replacement: step 7, image 1 of 1
    • Use small plastic opening tool to pry front facing camera flat top connector from the motherboard
  8. Toshiba Encore WT8-A Tablet  Camera Replacement: step 8, image 1 of 2 Toshiba Encore WT8-A Tablet  Camera Replacement: step 8, image 2 of 2
    • The front facing camera should come free at this point.
Melanie Mestre
116 Reputation
1 Guide authored
USF Tampa, Team 17-4, Blackwell Fall 2016 Member of USF Tampa, Team 17-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G4
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 693
