Toshiba NB205 N330PK RAM Replacement
  1. Toshiba NB205 N330PK RAM Replacement, RAM: step 1, image 1 of 2 Toshiba NB205 N330PK RAM Replacement, RAM: step 1, image 2 of 2
    • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
    • Lift the panel up and out of the way.
  2. Toshiba NB205 N330PK RAM Replacement: step 2, image 1 of 3 Toshiba NB205 N330PK RAM Replacement: step 2, image 2 of 3 Toshiba NB205 N330PK RAM Replacement: step 2, image 3 of 3
    • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
    • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
  3. Toshiba NB205 N330PK RAM Replacement: step 3, image 1 of 2 Toshiba NB205 N330PK RAM Replacement: step 3, image 2 of 2
    • Push the replacement RAM into the original position.
    • Reattach both securing arms onto the sides of the RAM chip.
  4. Toshiba NB205 N330PK RAM Replacement: step 4, image 1 of 2 Toshiba NB205 N330PK RAM Replacement: step 4, image 2 of 2
    • Place the panel back into the securing slots and let it rest in its original position.
    • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
Mason McCaskill
1,021 Reputation
9 Guides authored
Clemson, Team 14-2, Benson Fall 2013 Member of Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Members
27 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 524
