Toshiba NB305 Hard Drive Replacement
  1. Toshiba NB305 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Hard Drive Replacement: step 2, image 1 of 1
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Hard Drive Replacement: step 3, image 1 of 2 Toshiba NB305 Hard Drive Replacement: step 3, image 2 of 2
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 Toshiba NB305 Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 Toshiba NB305 Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
    • Locate the two torx T-6 screws on the back of the laptop and remove them.
    • 6mm Torx T-6 screws.
    • 3mm Torx T-6 screws.
  5. Toshiba NB305 Hard Drive Replacement: step 5, image 1 of 1
    • Note that the screw on the left is longer than the screw on the right.
  6. Toshiba NB305 Hard Drive Replacement: step 6, image 1 of 2 Toshiba NB305 Hard Drive Replacement: step 6, image 2 of 2
    • Using spudger, pry the panel up.
  7. Toshiba NB305 Hard Drive Replacement: step 7, image 1 of 1
    • Remove hard drive by pulling to the right and then upward and out.
Nuri Chung
368 Reputation
3 Guides authored
USF Tampa, Team 5-5, Lacy Fall 2016 Member of USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
3 Members
15 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,482
