Toshiba NB305 Keyboard Replacement
  1. Toshiba NB305 Keyboard  Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Keyboard  Replacement: step 2, image 1 of 1
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Keyboard  Replacement: step 3, image 1 of 2 Toshiba NB305 Keyboard  Replacement: step 3, image 2 of 2
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Keyboard  Replacement, Keyboard: step 4, image 1 of 2 Toshiba NB305 Keyboard  Replacement, Keyboard: step 4, image 2 of 2
    • Remove the four F4 screws and the F6 screw underneath battery.
    • 4mm Phillips-0 screws.
    • 6mm Phillips-0 screws.
  5. Toshiba NB305 Keyboard  Replacement: step 5, image 1 of 3 Toshiba NB305 Keyboard  Replacement: step 5, image 2 of 3 Toshiba NB305 Keyboard  Replacement: step 5, image 3 of 3
    • Using a spudger, gently pry out on the plastic cover.
    • Turn it over and remove plastic cover on top of laptop with power button on it.
  6. Toshiba NB305 Keyboard  Replacement: step 6, image 1 of 2 Toshiba NB305 Keyboard  Replacement: step 6, image 2 of 2
    • Use the plastic opening tool in little notches above the keyboard
    • Gently pry up on the keyboard until it lifts up.
    • You might hear a click when the keyboard releases.
  7. Toshiba NB305 Keyboard  Replacement: step 7, image 1 of 1
    • Gently lift the keyboard up toward the screen.
    • Be careful! There is a cable still connected from the computer to the keyboard.
  8. Toshiba NB305 Keyboard  Replacement: step 8, image 1 of 2 Toshiba NB305 Keyboard  Replacement: step 8, image 2 of 2
    • The ribbon cable has a clip on each side holding it to the motherboard.
    • Using a spudger, press on the clips to release the cable.
    • The cable will slide out on its own when it is properly released.
Nuri Chung
377 Reputation
3 Guides authored
USF Tampa, Team 5-5, Lacy Fall 2016 Member of USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
3 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 954
