Toshiba Portege M400 Keyboard Replacement
  1. Toshiba Portege M400 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Remove the front face plate with a plastic opening tool.
    • Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
  2. Toshiba Portege M400 Keyboard Replacement: step 2, image 1 of 1
    • Lift the keyboard toward you starting from the edge closest to the screen.
    • This ribbon still connects the taptor to the keyboard.
    • Gently place the keyboard on top of the track pad with the keys upside down.
  3. Toshiba Portege M400 Keyboard Replacement: step 3, image 1 of 3 Toshiba Portege M400 Keyboard Replacement: step 3, image 2 of 3 Toshiba Portege M400 Keyboard Replacement: step 3, image 3 of 3
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Remove the screw on the metal plate that keeps the ribbon from sliding out.
    • Gently remove the metal plate and set it aside.
  4. Toshiba Portege M400 Keyboard Replacement: step 4, image 1 of 2 Toshiba Portege M400 Keyboard Replacement: step 4, image 2 of 2
    • Dislodge the white ribbon connector from the two clips holding it in place using the plastic opening tools.
    • Pull out the white ribbon connector with your fingers.
Varsha Roopreddy
37 Reputation
4 Guides authored
Cal Poly, Team 4-17, Maness Spring 2013 Member of Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,054
