Toshiba Portege M400 Motherboard Replacement
  1. Toshiba Portege M400 Motherboard  Replacement, Motherboard: step 1, image 1 of 1
    • Using the plastic opening tool, remove the plastic hinge cover on the back of the laptop. Use caution not to damage this plastic cover.
  2. Toshiba Portege M400 Motherboard  Replacement: step 2, image 1 of 1
    • Using the plastic opening tool, remove the plastic cover directly above the keyboard. Make sure to start from the corners of the plastic cover.
  3. Toshiba Portege M400 Motherboard  Replacement: step 3, image 1 of 1
    • Using the #1 Phillips head screwdriver, remove the two 3.8mm screws.
  4. Toshiba Portege M400 Motherboard  Replacement: step 4, image 1 of 1
    • Remove the keyboard, make sure you gently remove any ribbon cables holding it to the rest of the computer. Bending or crimping a ribbon cable can break the device.
  5. Toshiba Portege M400 Motherboard  Replacement: step 5, image 1 of 2 Toshiba Portege M400 Motherboard  Replacement: step 5, image 2 of 2
    • Use a small phillips screwdriver to remove both metal shields as depicted.
  6. Toshiba Portege M400 Motherboard  Replacement: step 6, image 1 of 2 Toshiba Portege M400 Motherboard  Replacement: step 6, image 2 of 2
    • After removing the second metal covering you will remove the RAM compartment.
    • Simply pull apart the metal fasteners on the side; the RAM should pop out for removal.
  7. Toshiba Portege M400 Motherboard  Replacement: step 7, image 1 of 3 Toshiba Portege M400 Motherboard  Replacement: step 7, image 2 of 3 Toshiba Portege M400 Motherboard  Replacement: step 7, image 3 of 3
    • Disconnect the wire from the exposed wireless card.
    • Pry open the top of the laptop and gently remove and disconnect the wires as shown.
  8. Toshiba Portege M400 Motherboard  Replacement: step 8, image 1 of 2 Toshiba Portege M400 Motherboard  Replacement: step 8, image 2 of 2
    • Remove the screws attaching the motherboard to the plastic housing.
    • Lift off the motherboard. Once it is free of screws and you're done!
Dustin
1,213 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,271
