Toshiba Portege R700-S1312 Hard Drive Replacement
  1. Toshiba Portege R700-S1312 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 Hard Drive Replacement: step 2, image 1 of 1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 Hard Drive Replacement: step 3, image 1 of 3 Toshiba Portege R700-S1312 Hard Drive Replacement: step 3, image 2 of 3 Toshiba Portege R700-S1312 Hard Drive Replacement: step 3, image 3 of 3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the 40 mm screws from the RAM cover using a Phillips #00 Screwdriver.
  5. Toshiba Portege R700-S1312 Hard Drive Replacement: step 5, image 1 of 1
    • Lift and remove the RAM cover to reveal the first of 2 40mm screws holding down the hard drive cover. Remove the screw using a Phillips #00 Screwdriver.
  6. Toshiba Portege R700-S1312 Hard Drive Replacement: step 6, image 1 of 1
    • Remove the second 40mm hard drive cover screw using a Phillips #00 Screwdriver.
  7. Toshiba Portege R700-S1312 Hard Drive Replacement: step 7, image 1 of 1
    • Lift and remove the hard drive cover.
  8. Toshiba Portege R700-S1312 Hard Drive Replacement: step 8, image 1 of 1
    • Connect the drive (in this case a solid state drive) to the laptop using the SATA cable located inside the hard drive placement area.
  9. Toshiba Portege R700-S1312 Hard Drive Replacement: step 9, image 1 of 1
    • Once the drive is connected, carefully insert the drive into the laptop enclosure.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 2,530
