Toshiba Portege R700-S1312 RAM Replacement
  1. Toshiba Portege R700-S1312 RAM Replacement, Battery: step 1, image 1 of 1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 RAM Replacement: step 2, image 1 of 1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 RAM Replacement: step 3, image 1 of 3 Toshiba Portege R700-S1312 RAM Replacement: step 3, image 2 of 3 Toshiba Portege R700-S1312 RAM Replacement: step 3, image 3 of 3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 RAM Replacement, RAM: step 4, image 1 of 1
    • Flip the laptop over.
  5. Toshiba Portege R700-S1312 RAM Replacement: step 5, image 1 of 1
    • Using a Phillips #00 Screwdriver unscrew the 2 40mm screws that are located on the plate covering the RAM.
  6. Toshiba Portege R700-S1312 RAM Replacement: step 6, image 1 of 1
    • Remove the plate covering the RAM.
  7. Toshiba Portege R700-S1312 RAM Replacement: step 7, image 1 of 1
    • Pull the sides holding the RAM in place until there is a slight pop.
  8. Toshiba Portege R700-S1312 RAM Replacement: step 8, image 1 of 1
    • The RAM stick will lift up on its own. Simply remove it.
  9. Toshiba Portege R700-S1312 RAM Replacement: step 9, image 1 of 1
    • Place new RAM into the RAM drive and gently press until there is a slight pop.
To reassemble your device, simply follow steps 1-3 in reverse order.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 519
