Toshiba Portege R705-P35 DVD Drive Replacement
  1. Toshiba Portege R705-P35 DVD Drive Replacement, Battery: step 1, image 1 of 1
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 DVD Drive Replacement: step 2, image 1 of 1
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 DVD Drive Replacement: step 3, image 1 of 2 Toshiba Portege R705-P35 DVD Drive Replacement: step 3, image 2 of 2
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: step 4, image 1 of 3 Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: step 4, image 2 of 3 Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: step 4, image 3 of 3
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 DVD Drive Replacement, Hard Drive Plate: step 5, image 1 of 1
    • Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
  6. Toshiba Portege R705-P35 DVD Drive Replacement: step 6, image 1 of 2 Toshiba Portege R705-P35 DVD Drive Replacement: step 6, image 2 of 2
    • Use your hands to remove the hard drive plate from the laptop.
  7. Toshiba Portege R705-P35 DVD Drive Replacement, Back Plate: step 7, image 1 of 1
    • Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
  8. Toshiba Portege R705-P35 DVD Drive Replacement: step 8, image 1 of 2 Toshiba Portege R705-P35 DVD Drive Replacement: step 8, image 2 of 2
    • Lift and remove the small plate from the laptop.
  9. Toshiba Portege R705-P35 DVD Drive Replacement: step 9, image 1 of 1
    • Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
    • Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
  10. Toshiba Portege R705-P35 DVD Drive Replacement: step 10, image 1 of 2 Toshiba Portege R705-P35 DVD Drive Replacement: step 10, image 2 of 2
    • Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
  11. Toshiba Portege R705-P35 DVD Drive Replacement, DVD Drive: step 11, image 1 of 2 Toshiba Portege R705-P35 DVD Drive Replacement, DVD Drive: step 11, image 2 of 2
    • Use an opening tool to detach the hard drive connector from the DVD drive.
  12. Toshiba Portege R705-P35 DVD Drive Replacement: step 12, image 1 of 3 Toshiba Portege R705-P35 DVD Drive Replacement: step 12, image 2 of 3 Toshiba Portege R705-P35 DVD Drive Replacement: step 12, image 3 of 3
    • Remove the two 4 mm screws using a Phillips #00 screwdriver.
    • Remove the one 3 mm screw using a Phillips #00 screwdriver.
    • Remove the silver bracket that comes loose.
  13. Toshiba Portege R705-P35 DVD Drive Replacement: step 13, image 1 of 3 Toshiba Portege R705-P35 DVD Drive Replacement: step 13, image 2 of 3 Toshiba Portege R705-P35 DVD Drive Replacement: step 13, image 3 of 3
    • Pull on the orange bar with your fingers to detach it from the DVD drive.
    • Pull out and remove the DVD drive from the laptop.
Kathryn Hockenbury
833 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 197
