Toshiba Portege R705-P35 RAM Replacement
  1. Toshiba Portege R705-P35 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 RAM Replacement: step 2, image 1 of 1
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 RAM Replacement: step 3, image 1 of 2 Toshiba Portege R705-P35 RAM Replacement: step 3, image 2 of 2
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 RAM Replacement, RAM Plate: step 4, image 1 of 3 Toshiba Portege R705-P35 RAM Replacement, RAM Plate: step 4, image 2 of 3 Toshiba Portege R705-P35 RAM Replacement, RAM Plate: step 4, image 3 of 3
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 RAM Replacement, RAM: step 5, image 1 of 2 Toshiba Portege R705-P35 RAM Replacement, RAM: step 5, image 2 of 2
    • Using a spudger or your fingers, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise.
    • Repeat this procedure with the other metal rod on the opposite side of the RAM stick.
  6. Toshiba Portege R705-P35 RAM Replacement: step 6, image 1 of 2 Toshiba Portege R705-P35 RAM Replacement: step 6, image 2 of 2
    • Once the RAM stick pops out to an angle, pull it outward.
Kathryn Hockenbury
833 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 143
