Toshiba Portege R835-P88 Cooling Fan Replacement
  1. Toshiba Portege R835-P88 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement, Cooling Fan: step 1, image 3 of 3
    • Shut down the computer and unplug.
    • Unlock and remove battery.
  2. Toshiba Portege R835-P88 Cooling Fan Replacement: step 2, image 1 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement: step 2, image 2 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement: step 2, image 3 of 3
    • Remove the three small covers from the bottom by removing two 11mm screws and three 5mm screws using a screwdriver #J000.
    • Remove the remaining screws from the bottom cover using phillips head screwdriver #PH00.
  3. Toshiba Portege R835-P88 Cooling Fan Replacement: step 3, image 1 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement: step 3, image 2 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement: step 3, image 3 of 3
    • Pry the bottom cover using blue plastic ifixit prying tool.
    • Lift up and remove cover.
  4. Toshiba Portege R835-P88 Cooling Fan Replacement: step 4, image 1 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement: step 4, image 2 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement: step 4, image 3 of 3
    • Disconnect the fan cable from the motherboard.
    • Remove two 3mm screws from fan using #J000 phillips head screwdriver.
    • Lift up and remove fan.
  5. Toshiba Portege R835-P88 Cooling Fan Replacement: step 5, image 1 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement: step 5, image 2 of 3 Toshiba Portege R835-P88 Cooling Fan Replacement: step 5, image 3 of 3
    • Replace the fan.
    • Assemble the Toshiba Portege R835-P88 following all disassembly steps in the reverse direction.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,207
