Toshiba Portege R835-P88 Optical Drive Replacement
  1. Toshiba Portege R835-P88 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Start by removing the battery.
  2. Toshiba Portege R835-P88 Optical Drive Replacement: step 2, image 1 of 2 Toshiba Portege R835-P88 Optical Drive Replacement: step 2, image 2 of 2
    • Start by removing the back cover by removing the screws, revealing the Optical Drive. Remove the 1 cm screws to remove. Then use the spudger to pry the back off.
  3. Toshiba Portege R835-P88 Optical Drive Replacement: step 3, image 1 of 1
    • After the cover is removed, remove the screws that hold the Drive. It has 3, 1 cm screws holding it down.
  4. Toshiba Portege R835-P88 Optical Drive Replacement: step 4, image 1 of 1
    • Take the 2, .5 cm screws out of the drive line. Once this is complete, you have successfully taken out the Optical Drive.
Colt Cates
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 675
