Toshiba Portege R835-P88 Screen Replacement
  1. Toshiba Portege R835-P88 Screen Replacement, Screen: step 1, image 1 of 1
    • Remove the battery by pressing the two buttons inward and pulling the battery out.
  2. Toshiba Portege R835-P88 Screen Replacement: step 2, image 1 of 1
    • Remove the end caps located on the left and right corners below the screen.
  3. Toshiba Portege R835-P88 Screen Replacement: step 3, image 1 of 1
    • Remove the square rubber caps on top of the screws
    • Remove the 4 mm screws at the top
    • remove the two 6 mm screws that were under the chrome caps at the bottom.
  4. Toshiba Portege R835-P88 Screen Replacement: step 4, image 1 of 1
    • Remove the plastic bezel by lightly prying on it. It will pop when it starts to come loose.
  5. Toshiba Portege R835-P88 Screen Replacement: step 5, image 1 of 2 Toshiba Portege R835-P88 Screen Replacement: step 5, image 2 of 2
    • Remove tape from around cord attached to the bottom of the screen.
    • Place the screen on top of the keyboard
  6. Toshiba Portege R835-P88 Screen Replacement: step 6, image 1 of 3 Toshiba Portege R835-P88 Screen Replacement: step 6, image 2 of 3 Toshiba Portege R835-P88 Screen Replacement: step 6, image 3 of 3
    • Remove the cord from the screen by cutting the tape where the two fittings meet. After that pull them apart.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 462
