Toshiba Qosmio X305-Q704 Fan Replacement
  1. Toshiba Qosmio X305-Q704 Fan Replacement, Keyboard: step 1, image 1 of 1
    • Find an edge of the red strip along the edge the computer and pry it off using a spudger.
  2. Toshiba Qosmio X305-Q704 Fan Replacement: step 2, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 2, image 2 of 2
    • Find an edge of the black cover piece around the keyboard and pry it up using the spudger.
  3. Toshiba Qosmio X305-Q704 Fan Replacement: step 3, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 3, image 2 of 2
    • Lift the keyboard up and detach the strip connecting the keyboard to the back of the laptop.
  4. Toshiba Qosmio X305-Q704 Fan Replacement: step 4, image 1 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 4, image 2 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 4, image 3 of 3
    • Remove the keyboard from the Laptop.
  5. Toshiba Qosmio X305-Q704 Fan Replacement, Screen: step 5, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement, Screen: step 5, image 2 of 2
    • Unscrew the four 10 mm screws with the Phillips #0 screwdriver.
  6. Toshiba Qosmio X305-Q704 Fan Replacement: step 6, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 6, image 2 of 2
    • Insert the iFixit opening tool into the side of the computer that separates the top and bottom of the laptop. Move the tool along the edge of the laptop until the cover can be separated from the device.
    • Do not remove the panel from the device, as you'll need to disconnect cables before the component can be fully removed.
  7. Toshiba Qosmio X305-Q704 Fan Replacement: step 7, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 7, image 2 of 2
    • Disconnect all wires connecting the top piece to the bottom.
  8. Toshiba Qosmio X305-Q704 Fan Replacement: step 8, image 1 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 8, image 2 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 8, image 3 of 3
    • Disconnect all wires connecting the screen to the inside of the computer.
  9. Toshiba Qosmio X305-Q704 Fan Replacement: step 9, image 1 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 9, image 2 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 9, image 3 of 3
    • Remove the 6 mm screws holding the screen on to the laptop using a Phillips #0 screwdriver.
  10. Toshiba Qosmio X305-Q704 Fan Replacement: step 10, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 10, image 2 of 2
    • Remove the screen from the laptop.
  11. Toshiba Qosmio X305-Q704 Fan Replacement, Fan: step 11, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement, Fan: step 11, image 2 of 2
    • Remove the four 8 mm screws holding the two circuit boards together using a Phillips #0 screwdriver.
  12. Toshiba Qosmio X305-Q704 Fan Replacement: step 12, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 12, image 2 of 2
    • Remove the top circuit board.
  13. Toshiba Qosmio X305-Q704 Fan Replacement: step 13, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 13, image 2 of 2
    • Remove all of the 8 mm screws holding the bottom circuit board to the bottom of the computer using the Phillips #0 screwdriver.
  14. Toshiba Qosmio X305-Q704 Fan Replacement: step 14, image 1 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 14, image 2 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 14, image 3 of 3
    • Disconnect all wires from the circuit board.
  15. Toshiba Qosmio X305-Q704 Fan Replacement: step 15, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 15, image 2 of 2
    • Lift the circuit board from the inside of the laptop.
  16. Toshiba Qosmio X305-Q704 Fan Replacement: step 16, image 1 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 16, image 2 of 3 Toshiba Qosmio X305-Q704 Fan Replacement: step 16, image 3 of 3
    • Disconnect the wire underneath connecting the fan to the circuit board.
  17. Toshiba Qosmio X305-Q704 Fan Replacement: step 17, image 1 of 1
    • Unscrew the 6 mm screw holding the fan in place using the Phillips #0 screwdriver.
  18. Toshiba Qosmio X305-Q704 Fan Replacement: step 18, image 1 of 2 Toshiba Qosmio X305-Q704 Fan Replacement: step 18, image 2 of 2
    • Lift the fan and remove it from the device.
2 other people completed this guide.
VivianPham0719
361 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 474
