Toshiba Qosmio X775-3DV80 Wifi Chip Replacement
  1. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Battery: step 1, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Battery: step 1, image 2 of 2
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 2, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 2, image 2 of 2
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 3, image 1 of 1
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Optical Drive: step 4, image 1 of 1
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 6, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 6, image 2 of 2
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, RAM: step 7, image 1 of 1
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 8, image 1 of 1
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 9, image 1 of 3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 9, image 2 of 3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 9, image 3 of 3
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Keyboard: step 10, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Keyboard: step 10, image 2 of 2
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 11, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 11, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 12, image 1 of 1
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 13, image 1 of 3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 13, image 2 of 3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 13, image 3 of 3
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
  14. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Fan: step 14, image 1 of 1
    • Separate the two halves of the base of the laptop.
  15. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 15, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 15, image 2 of 2
    • Disconnect the two cables.
  16. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 16, image 1 of 1
    • Remove the palmrest assembly.
  17. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 17, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 17, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the four screws securing the fan assembly to the laptop.
  18. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 18, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 18, image 2 of 2
    • Unplug the fan-motherboard connector.
    • Remove the fan unit.
  19. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Wifi Chip: step 19, image 1 of 1
    • Detach the two coaxial connections from the wifi chip.
  20. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 20, image 1 of 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 20, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the two screws from the wifi chip.
  21. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: step 21, image 1 of 1
    • Remove the wifi chip by pulling it out of the PCIe slot.
Jesse Adam Ory
745 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 598
