Toshiba SD-K740 Disc Drive Replacement
  1. Toshiba SD-K740 Disc Drive Replacement, Top Panel: step 1, image 1 of 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Disc Drive Replacement: step 2, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement: step 2, image 2 of 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Disc Drive Replacement: step 3, image 1 of 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Disc Drive Replacement, Front Panel: step 4, image 1 of 1
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Disc Drive Replacement: step 5, image 1 of 1
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Disc Drive Replacement: step 6, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement: step 6, image 2 of 2
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Disc Drive Replacement, Disc Drive: step 7, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement, Disc Drive: step 7, image 2 of 2
    • Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
  8. Toshiba SD-K740 Disc Drive Replacement: step 8, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement: step 8, image 2 of 2
    • Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
  9. Toshiba SD-K740 Disc Drive Replacement: step 9, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement: step 9, image 2 of 2
    • Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
  10. Toshiba SD-K740 Disc Drive Replacement: step 10, image 1 of 1
    • Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
  11. Toshiba SD-K740 Disc Drive Replacement: step 11, image 1 of 1
    • Lift disc drive vertically to remove.
Joe Murphy
542 Reputation
5 Guides authored
Cal Poly, Team 1-16, Amido Winter 2011 Member of Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,642
