Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement
Kiril Lange
Kiril Lange and 3 other contributors
Last updated on April 29, 2023
30 - 45 minutes
Moderate
Introduction
Go to step 1
An overheating laptop, or an always on noisy fan, can be caused by a clogged heatsink, clogged fan, broken fan, or bad thermal paste.
This procedure is similar to the Satellite 1410.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Battery: step 1, image 1 of 1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 2, image 1 of 1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 3, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 3, image 2 of 2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 4, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 4, image 2 of 2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Lower Case: step 5, image 1 of 1
    • Unscrew all of the visible screws on the bottom of the laptop.
    • The screws circled are not necessary to remove.
    • Keeping track of which hole each screw goes in will speed up reassembly.
  6. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 6, image 1 of 1
    • Unscrew the screws located beneath the battery.
  7. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: step 7, image 1 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: step 7, image 2 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: step 7, image 3 of 3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  8. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 8, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 8, image 2 of 2
    • Unscrew the two screws near the top of the keyboard.
  9. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 9, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 9, image 2 of 2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  10. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 10, image 1 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 10, image 2 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 10, image 3 of 3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  11. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: step 11, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: step 11, image 2 of 2
    • Unscrew the screws on either side of the power button circuit board.
  12. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 12, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 12, image 2 of 2
    • Pull upward on the small white ribbon cable to detach from circuit board.
  13. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Optical Drive: step 13, image 1 of 1
    • Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
  14. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 14, image 1 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 14, image 2 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 14, image 3 of 3
    • Using spudger, push the optical drive out to the right.
  15. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: step 15, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: step 15, image 2 of 2
    • Disconnect both speaker connectors located near the center of the laptop.
  16. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 16, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 16, image 2 of 2
    • Unscrew all visible screws on the heat sink shield.
  17. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 17, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 17, image 2 of 2
    • Disconnect the monitor connector.
  18. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 18, image 1 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 18, image 2 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 18, image 3 of 3
    • Starting from the front right corner pry apart the black bottom from the gray top.
  19. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 19, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 19, image 2 of 2
    • Set aside the top half.
  20. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: step 20, image 1 of 2 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: step 20, image 2 of 2
    • Unscrew the remaining screws on the heatsink and fan brackets.
  21. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 21, image 1 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 21, image 2 of 3 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 21, image 3 of 3
    • Disconnect the fan power connector.
    • Remove the heatsink and fan.
    • Check the heatsink fins and fan for any dust build-up. If any is found use compressed air to clean.
  22. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: step 22, image 1 of 1
    • Clean the old thermal paste off the CPU and heatsink.
    • Use a q tip to remove the majority of the thermal paste.
    • Use an isopropyl alcohol soaked q tip to further clean remaining thermal paste.
    • Dry and clean both surfaces with another q-tip.
    • Once completely clean, apply a rice grain sized amount of new thermal paste to the CPU and reattach the heatsink and fan.
Kiril Lange
943 Reputation
9 Guides authored
USF Tampa, Team 3-2, Brown Fall 2014 Member of USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Members
27 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 953
