Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement
Kiril Lange
Kiril Lange and one other contributor
Last updated on April 29, 2023
15 - 20 minutes
Moderate
Introduction
Go to step 1
A working power button makes the difference between a working laptop and a brick. If your laptop refuses to turn on or doesn't respond to power button presses; replacing the power button circuit board may fix it.
Tools
  1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Battery: step 1, image 1 of 1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 2, image 1 of 1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 3, image 1 of 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 3, image 2 of 2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 4, image 1 of 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 4, image 2 of 2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: step 5, image 1 of 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: step 5, image 2 of 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: step 5, image 3 of 3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 6, image 1 of 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 6, image 2 of 2
    • Unscrew the two screws near the top of the keyboard.
  7. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 7, image 1 of 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 7, image 2 of 2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 8, image 1 of 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 8, image 2 of 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 8, image 3 of 3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  9. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: step 9, image 1 of 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: step 9, image 2 of 2
    • Unscrew the screws on either side of the power button circuit board.
  10. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 10, image 1 of 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: step 10, image 2 of 2
    • Pull upward on the small white ribbon cable to detach from circuit board.
Kiril Lange
943 Reputation
9 Guides authored
USF Tampa, Team 3-2, Brown Fall 2014 Member of USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Members
27 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 21
All Time: 1,615
