Toshiba Satellite 1415-S105 RAM Replacement
  1. Toshiba Satellite 1415-S105 RAM Replacement, Memory Cover: step 1, image 1 of 2 Toshiba Satellite 1415-S105 RAM Replacement, Memory Cover: step 1, image 2 of 2
    • The RAM access panel is located near the middle of the bottom.
  2. Toshiba Satellite 1415-S105 RAM Replacement: step 2, image 1 of 1
    • Unscrew the single screw labeled F4 on the panel.
  3. Toshiba Satellite 1415-S105 RAM Replacement: step 3, image 1 of 1
    • Using a spudger, inserted into the notch under the screw hole, pry open and remove the cover.
  4. Toshiba Satellite 1415-S105 RAM Replacement, RAM: step 4, image 1 of 2 Toshiba Satellite 1415-S105 RAM Replacement, RAM: step 4, image 2 of 2
    • Pull outward on each pair of restraining clips to free each chip.
  5. Toshiba Satellite 1415-S105 RAM Replacement, Removal: step 5, image 1 of 2 Toshiba Satellite 1415-S105 RAM Replacement, Removal: step 5, image 2 of 2
    • The RAM chips can now be pulled out.
    • This laptop supports a maximum of two memory modules. The largest capacity for each is 256MB of PC1600 DDR SDRAM.
Kiril Lange
943 Reputation
9 Guides authored
USF Tampa, Team 3-2, Brown Fall 2014 Member of USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Members
27 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 293
