Toshiba Satellite 1415-S105 Upper Case Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Toshiba Satellite 1415-S105 Upper Case Replacement, Upper Case: step 1, image 1 of 2 Toshiba Satellite 1415-S105 Upper Case Replacement, Upper Case: step 1, image 2 of 2
    • Disconnect both speaker connectors located near the center of the laptop.
  2. Toshiba Satellite 1415-S105 Upper Case Replacement: step 2, image 1 of 2 Toshiba Satellite 1415-S105 Upper Case Replacement: step 2, image 2 of 2
    • Unscrew all visible screws on the heat sink shield.
  3. Toshiba Satellite 1415-S105 Upper Case Replacement: step 3, image 1 of 2 Toshiba Satellite 1415-S105 Upper Case Replacement: step 3, image 2 of 2
    • Disconnect the monitor connector.
  4. Toshiba Satellite 1415-S105 Upper Case Replacement: step 4, image 1 of 3 Toshiba Satellite 1415-S105 Upper Case Replacement: step 4, image 2 of 3 Toshiba Satellite 1415-S105 Upper Case Replacement: step 4, image 3 of 3
    • Starting from the front right corner pry apart the black bottom from the gray top.
  5. Toshiba Satellite 1415-S105 Upper Case Replacement: step 5, image 1 of 2 Toshiba Satellite 1415-S105 Upper Case Replacement: step 5, image 2 of 2
    • Set aside the top half.
Kiril Lange
943 Reputation
9 Guides authored
USF Tampa, Team 3-2, Brown Fall 2014 Member of USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Members
27 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 46
