Toshiba Satellite 1805-S177 Hard Drive Replacement
Hannah
Hannah and 9 other contributors
Last updated on May 1, 2023
3 - 5 minutes
Easy
Missing Prerequisites
Introduction
Go to step 1
This guide tells you how to replace the current hard drive in the laptop with one of better storage or functionality.
  1. Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
    • The hard drive is located next to the CD drive.
  2. Toshiba Satellite 1805-S177 Hard Drive Replacement: step 2, image 1 of 1
    • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
  3. Toshiba Satellite 1805-S177 Hard Drive Replacement: step 3, image 1 of 2 Toshiba Satellite 1805-S177 Hard Drive Replacement: step 3, image 2 of 2
    • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  4. Toshiba Satellite 1805-S177 Hard Drive Replacement: step 4, image 1 of 1
    • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
    • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Hannah
227 Reputation
7 Guides authored
Cal Poly, Team 3-5, Johann Summer 2010 Member of Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Members
24 Guides authored
One Comment
How can I run a cd if I can't remember my hdd password on my toshiba l645 computer
Vera Hess - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 15
All Time: 4,240
