Toshiba Satellite 1805-S177 Keyboard Replacement
Hannah
Hannah and 9 other contributors
Last updated on May 1, 2023
3 - 5 minutes
Easy
Incorrect Tools
Missing Prerequisites
Introduction
Go to step 1
Oftentimes, things get stuck in between keys, or keys labels get worn out with use. This guide will assist in replacing that broken keyboard with a new one.
Tools
Show more…
  1. Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  2. Toshiba Satellite 1805-S177 Keyboard Replacement: step 2, image 1 of 3 Toshiba Satellite 1805-S177 Keyboard Replacement: step 2, image 2 of 3 Toshiba Satellite 1805-S177 Keyboard Replacement: step 2, image 3 of 3
    • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  3. Toshiba Satellite 1805-S177 Keyboard Replacement: step 3, image 1 of 1
    • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
    • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
  4. Toshiba Satellite 1805-S177 Keyboard Replacement: step 4, image 1 of 2 Toshiba Satellite 1805-S177 Keyboard Replacement: step 4, image 2 of 2
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Slide the white ribbon connector up and lift the ribbon out of it.
Hannah
227 Reputation
7 Guides authored
Cal Poly, Team 3-5, Johann Summer 2010 Member of Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,712
