Toshiba Satellite 1805-S177 RAM Replacement
  1. Toshiba Satellite 1805-S177 RAM Replacement, RAM: step 1, image 1 of 2 Toshiba Satellite 1805-S177 RAM Replacement, RAM: step 1, image 2 of 2
    • Using a Phillips screwdriver, unscrew and remove two screws labeled F4 from the plastic piece on the back of the laptop with the RAM indicator.
  2. Toshiba Satellite 1805-S177 RAM Replacement: step 2, image 1 of 1
    • Using a flathead screwdriver or a shiv, insert the flathead of the screwdriver in the space between the plastic piece and the rest of the laptop. Pry the plastic piece off by moving the flathead screwdriver up and down.
  3. Toshiba Satellite 1805-S177 RAM Replacement: step 3, image 1 of 3 Toshiba Satellite 1805-S177 RAM Replacement: step 3, image 2 of 3 Toshiba Satellite 1805-S177 RAM Replacement: step 3, image 3 of 3
    • Using your fingers, push two shorter sides of RAM away from each other.
    • Note: The RAM should pop up automatically.
  4. Toshiba Satellite 1805-S177 RAM Replacement: step 4, image 1 of 2 Toshiba Satellite 1805-S177 RAM Replacement: step 4, image 2 of 2
    • Using your fingers, pull RAM out of the laptop by gentling lifting up.
    • When reinstalling ram be sure to line up the ram correctly with the slot and notch in the ram
4 other people completed this guide.
Hannah
227 Reputation
7 Guides authored
Cal Poly, Team 3-5, Johann Summer 2010 Member of Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Members
24 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 2,793
