Toshiba Satellite A105-S4011 Battery Replacement
  1. Toshiba Satellite A105-S4011 Battery Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A105-S4011 Battery Replacement, Battery: step 1, image 2 of 2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Battery Replacement: step 2, image 1 of 2 Toshiba Satellite A105-S4011 Battery Replacement: step 2, image 2 of 2
    • Hold the release switch and pull out the battery towards you.
6 other people completed this guide.
Lucas Salisbury
73 Reputation
3 Guides authored
Cal Poly, Team 4-14, Maness Spring 2013 Member of Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
4 Members
14 Guides authored
2 Comments
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
Benjamin Osei - Reply
The part number is PSUB2U-00K00P
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 1,344
