Toshiba Satellite A105-S4011 Hard Disk Drive Replacement
Introduction
Go to step 1This guide will show you how to remove the current Hard Drive and how to replace it. Accessing the Hard Drive in this computer is straightforward and only requires minimal dis-assembly with a screwdriver. Make sure your new hard disk is compatible with your device before attempting to install it because it may not fit, may have different wiring, etc.
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Turn the laptop so the battery-side of the laptop is farthest from you. Locate the captive screw pictured here and loosen the screw using the #1 Phillips screwdriver.
4 other people completed this guide.
