Toshiba Satellite A105-S4074 Battery Replacement
  1. Toshiba Satellite A105-S4074 Battery Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A105-S4074 Battery Replacement, Battery: step 1, image 2 of 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Battery Replacement: step 2, image 1 of 3 Toshiba Satellite A105-S4074 Battery Replacement: step 2, image 2 of 3 Toshiba Satellite A105-S4074 Battery Replacement: step 2, image 3 of 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
To reassemble your device after inserting the replacement battery, follow these instructions in reverse order.
3 other people completed this guide.
Ryan Bortnick
722 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 403
