Toshiba Satellite A105-S4284 Hard Drive Replacement
  1. Toshiba Satellite A105-S4284  Hard Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A105-S4284  Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: step 2, image 1 of 3 Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: step 2, image 2 of 3 Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: step 2, image 3 of 3
    • Turn the laptop around 180 degrees.
    • Unscrew the 4 mm screw with the Philips #1 screwdriver.
    • Lift and remove the hard drive cover.
  3. Toshiba Satellite A105-S4284  Hard Drive Replacement: step 3, image 1 of 3 Toshiba Satellite A105-S4284  Hard Drive Replacement: step 3, image 2 of 3 Toshiba Satellite A105-S4284  Hard Drive Replacement: step 3, image 3 of 3
    • Pull on the rubber tab to slide the hard drive to the left.
    • Pick up the near side of the hard drive and pull it out the back.
pfedigan
11 Reputation
4 Guides authored
Cal Poly, Team 2-23, Maness Spring 2013 Member of Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,472
