Toshiba Satellite A105-S4284 Disc Drive Replacement
pfedigan
pfedigan and 8 other contributors
Last updated on May 14, 2023
10 minutes
Moderate
Better Introduction
Introduction
Go to step 1
If your CDs or DVDs are not running correctly or at all on your computer, then it is either due to the disc drive being dirty, loose parts and/or broken. This guide will show the user how to safely remove the disc drive.
Tools
Show more…
  1. Toshiba Satellite A105-S4284 Disc Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A105-S4284 Disc Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Disc Drive Replacement, Disc Drive: step 2, image 1 of 2 Toshiba Satellite A105-S4284 Disc Drive Replacement, Disc Drive: step 2, image 2 of 2
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 Disc Drive Replacement: step 3, image 1 of 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: step 3, image 2 of 2
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 Disc Drive Replacement: step 4, image 1 of 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: step 4, image 2 of 2
    • Remove the 4.0 mm screw above the small metal tab with a Phillips 00 screwdriver.
  5. Toshiba Satellite A105-S4284 Disc Drive Replacement: step 5, image 1 of 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: step 5, image 2 of 2
    • Push down on the metal tab under the cover with the plastic opening tool and push the disc drive partially out.
    • Grab the drive and pull it out of the laptop.
pfedigan
11 Reputation
4 Guides authored
Cal Poly, Team 2-23, Maness Spring 2013 Member of Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 909
