Toshiba Satellite A205-S4577 Hard Drive Replacement
  1. Toshiba Satellite A205-S4577 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Locate the hard drive cover on the bottom, left-hand corner of your laptop.
    • Using a Phillips #00 screwdriver, remove both 4mm screws.
  2. Toshiba Satellite A205-S4577 Hard Drive Replacement: step 2, image 1 of 1
    • Lift the cover to reveal the old hard drive.
    • Carefully detach the hard drive from the SATA/Power connector.
  3. Toshiba Satellite A205-S4577 Hard Drive Replacement: step 3, image 1 of 1
    • After removing the old hard drive, place the new hard drive into the bay, and firmly reattach it to the SATA/Power connector.
Daniel Johnson
111 Reputation
4 Guides authored
Cal Poly, Team 17-6, Regan Spring 2013 Member of Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Members
33 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 13
Past 30 Days: 22
All Time: 2,529
