Toshiba Satellite A205-S4577 Speaker Cover Replacement
  1. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Battery: step 1, image 1 of 1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Speaker Cover Replacement: step 2, image 1 of 1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: step 3, image 1 of 3 Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: step 3, image 2 of 3 Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: step 3, image 3 of 3
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Speaker Cover Replacement: step 4, image 1 of 1
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Speaker Cover Replacement: step 5, image 1 of 1
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
Daniel Johnson
111 Reputation
4 Guides authored
Cal Poly, Team 17-6, Regan Spring 2013 Member of Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Members
33 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 15
All Time: 1,355
