Toshiba Satellite A210 Keyboard Replacement
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A210 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite A210 Keyboard Replacement: step 2, image 2 of 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: step 4, image 1 of 3 Toshiba Satellite A210 Keyboard Replacement: step 4, image 2 of 3 Toshiba Satellite A210 Keyboard Replacement: step 4, image 3 of 3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: step 5, image 1 of 2 Toshiba Satellite A210 Keyboard Replacement: step 5, image 2 of 2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: step 6, image 1 of 1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
3 other people completed this guide.
Youlen
49 Reputation
2 Guides authored
Cal Poly, Team 17-5, Regan Spring 2013 Member of Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Members
18 Guides authored
One Comment
very useful. THANKS
ANDREAS - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 2,677
